Prototype animation weird "jump" up-down
iraida19031989
hello everyone, im pretty new in Figma and I follow some lessons from Youtube to prove my skills.
so I faced some problem : I made several copy of first screen ,after I changed them one by one how I want my acting change it. i used : while hovering - navigate to - smart animation .
so when prototype is running , I scroll page down from first screen to second or third , hover object and animation works around 0.001 second and after jump up to first screenโ€ฆ
if you understand my English and my problem PLS HELP ๐Ÿ˜‰
Haroll
  • 273 replies
  • January 8, 2024
Hi @iraida19031989
Would you be able to share the prototype, and explain what behavior do you want to achieve so we can better visualize the problem ?
iraida19031989
hi, yes sure.
The problem is animation jump from 2nd and 3d block to 1st block of landing exact after 1 sec I make while hovering for object.
thank you for your attention ๐Ÿ™
https://www.figma.com/file/1BbbGYvIMLde8TBeqrHE39/zny?type=design&node-id=0%3A1&mode=design&t=KOg67KWKAxXDN8w3-1
uipastel
  • 30 replies
  • January 9, 2024
Hi, if you are using animation, you can animate with component set and make some effect per-block, you can select your design effect in assets beside layers and drag in your design effect.
You can try the tutorial: Scroll Animations in Figma! (Without scroll support) (youtube.com)
If you have more complex or different animation you can help again
