Preview suddenly stopped scaling the preview window
Marcus_Wallinder
Hi!
For some reason the Preview suddenly stopped scaling when I resize it to check my prototypes. For clarity, this happens when I’ve hit shift-space, and resize the preview either from the right side, or from the bottom. It just makes the preview screen bigger, and doesn’t scale the window like it used to do.
First this happened in browser mode, and I couldn’t figure out what was wrong so I downloaded the Windows app and there it worked properly on all my prototypes. A few hours later just now it stopped working in the Windows app too.
If I check on my other computer, a laptop, the Preview scales correctly.
I’ve disabled all Chrome extensions and rebooted, nothing works.
For reference the app scales under the menu here, so weird.
Ryan_52
  • 382 replies
  • October 26, 2023
Hi @Marcus_Wallinder do you happen to have a device frame set?
Marcus_Wallinder
Yes, I used the “iPhone 13 & 14” device frame, I have since renamed it.
Marcus_Wallinder
Do you think its has something to do with this?
Emma_Stephens
This also just started happening to me.
I’m not using a device frame on my prototype.
It was working as expected (I scale my preview window and the prototype scales along with it) and then not even 5 mins later, directly after the update it now stops scaling.
Feels to me like it might have had something to do with the recent update
Emma_Stephens
Some additional information that I have just discovered… when clicking the “Fit frame to aspect ratio” it scales the window to the correct ratio, but the prototype spills outside of the frame. See image attached
Ryan_52
  • 382 replies
  • October 30, 2023
Thank you both for the reply and sorry to hear this is happening! @Emma_Stephens The issue regarding the “Fit to frame aspect ratio” does seem strange, can you please reach out to our support team directly via this form: https://help.figma.com/hc/en-us/requests/new so they can take a closer look. Please include a short video and a link to the file and share it with support-share@figma.com
@Marcus_Wallinder I suspect it had something to do with the device frame on the prototype being set. If changing that to “None” doesn’t help can you also please reach out to our support team via the same forum linked above.
Klaman
  • May 30, 2024
Was there ever a solution here? This just started happened in some of my files as well and can’t tell why…
  • 5083 replies
  • May 31, 2024
Hey @Klaman, sorry to hear you’re having this issue!
We didn’t receive a screen recording or file from the previous users. If you can, share a file with us here: https://help.figma.com/hc/en-us/requests/new
Please use your Figma account email, include a link to the file, and share edit access with support-share@figma.com, so the team can take a closer look.
  • June 6, 2024
Is there any update on this? I’ve been struggling with this for a few weeks now in several different Figma projects and I can’t find any solution (MacOS client).
  • 5083 replies
  • June 7, 2024
Hey @Bram_Bos,
Nothing yet. We still haven’t received a screen recording or file from the previous users. If you can, share a file with us here: https://help.figma.com/hc/en-us/requests/new
  • June 14, 2024
Unfortunately I can’t share a screen recording right now because my current projects are confidential.
But I have found that the solution is to reload the page by right-clicking on the document tab in the MacOS client. After reloading the page the scaling works correctly again - so it seems like this is a bug and not a feature I have overlooked.
