PDF Export not attaching all links
Lauren_McKeen
Creating a one pager and need links to be exported with the PDF. For some reason only a few of the links are working after export but not all. Has anyone figured out how to make all the links work when exporting to PDF?
Lesley_Mace
Knowing how to export one jam to pdf would be great !!
asli
  • August 31, 2022
If you select your text, you should be able to see a symbol on top of the file, next to the “create component”- symbol. If you click the symbol, it creates a hyper link for you, which should work after downloading the file
Eduard_Lache
What @asli said works but automatically adds an underline (which can be removed from “Type settings → Decorations → None” ). Also you can’t make it open in a new tab.
What I noticed is that if you rename the text to something that start with “www.” or “https://” or looks like an email address the link does work with the "Prototype → Interactions → On click → Open link " and you can make it open in new tab. But you will need to change the inner text to make it work.
