Offset path to create "radiating" outlined shapes?
DNLBTLR
In illustrator, I believe there’s an effect called “offset path” that will give this result.
Is there anyway to do this in Figma?
Best answer by Ian_Sampaio
And another method using Difference and Luminance mask. This is by far the simplest but your object will carry a masked fill (you can lock your layers to avoid messing with it)
Ian_Sampaio
To my knowledge Figma doesn’t offer layered paths and I’m afraid it will never do since it usually follows what is possible to through CSS. But here is a workaround: create a symbol with the desired path and a stroke (I added both black and white to easily alternate between the two). The effect is achieved by each instance below the main symbol getting a thicker stroke and alternate between black and white:
Figma
Ian_Sampaio
I’ve added a second approach which uses Merge. It’s a lot simpler and allows transparency but also buggier (you can try and get rid of the bugs messing with the outer stroke’s Miter angle)
Ian_Sampaio
