Object properties not carried over between code and ui
  • June 22, 2023
  • 284 views
Here is my code:
code.js
const variableCollection = figma.variables.getLocalVariableCollections();
const variables = figma.variables.getLocalVariables();
showUI(
      height: 137,
      width: 240,
    { collections: variableCollection, vars: variables }
ui.js
function Plugin(props: {
  collections: VariableCollection[];
  vars: Variable[];
const collectionComponents = props.collections.map((node) => {
    return <Text>{node.name}</Text>;
For some reason, when I send the prop through, some keys gets removed. What is causing this?
Below is an image of how it looks like before and after
  • 4871 replies
  • June 22, 2023
As you can see, all property values, except for id, have not been evaluated and are displayed in the console as (…). Therefore, you need to create a copy of objects with already evaluated values, and only then send this copy to the UI. You can get these values by calling the getters of the required properties.
