Need more controls on stroke customisation
Deep_Shah
  • 4710 replies
  • October 27, 2023
Yes:
Deep_Shah
  • 18 replies
  • October 27, 2023
It was not work
  • 4710 replies
  • October 27, 2023
Your video literally shows that it works.
Fernando_Lins
  • 44 replies
  • October 27, 2023
@Gleb The strokes they showed on the first post have a dent in them, yours are perfectly square.
@Deep_Shah You cannot create custom ends like that in your stroke from the stroke panel, you would have to draw that shape with the pen tool or by using rectangles and editing them.
  • 4710 replies
  • October 27, 2023
Ah, so you think they want the opposite of sharp edges? I thought the original shape is an outlined arrow with sharp corners and a stroke that has bevel angles set like this. Much easier to create it this way instead of using a pen tool manually.
Deep_Shah
  • 18 replies
  • October 30, 2023
I want to use this effect on a stroke, not a shape, as I previously stated. I appreciate your assistance, however it was ineffective in this instance. I will need to shape my icons before applying the stroke effect. Since Adobe Illustrator will offer these kinds of options, I believe I will need to switch to it in order to finish this.
  • 4710 replies
  • October 30, 2023
Duplicate an object, put it into a union, remove the duplicated copy from the union leaving only one object inside and add stroke to the union.
Deep_Shah
  • 18 replies
  • November 1, 2023
Facing issues in applying this. Can you please share a short video on this? I feel it may works
  • 4710 replies
  • November 1, 2023
The steps are super simple, can you try again and let me know what step you are not getting?
Deep_Shah
  • 18 replies
  • November 2, 2023
How did you apply union to a stroke? I think there is no way to do that. Can you create multiple artboards for each step and share a file so I understand the techniques you used?
  • 4710 replies
  • November 2, 2023
means you need to press Cmd + D and then union both (since union can’t be created with one object only)
Deep_Shah
  • 18 replies
  • November 2, 2023
Got it! Thus, in this instance, we have both controls to control the applied stroke as well as the original path’s stroke.
  • 4710 replies
  • November 2, 2023
Yep! Non destructive method. I’m not sure you can do something like this in Illustrator even, I think all methods in Illustrator would be destructive.
Deep_Shah
  • 18 replies
  • November 2, 2023
You just have to manage the calculations for your path and stroke. Example: If you want to create an icon with a 1px stroke, you need to give 0.5px to the path and 0.5px to the stroke to manipulate it.
