Multi edit - Bring back shift+drag for regular add to selection
Zoe_Gomez
With the new multi edit updates if you have something selected and then shift+drag over other items, it now only selects matching items, not everything you have dragged over.
While this is a useful feature, I rely on shift+drag to add other items to a selection all the time. It does still allow for shift+click to add to the selection but I rely on the drag to select a lot of things.
This has completely broken my usual workflows!
I feel the multi edit matching select should be a different short cut like shift+command+drag.
It definitely has its place in the product but personally I feel it is no where near as useful/common as just regularly adding to a selection.
Cindy_Le
  • 4 replies
  • March 11, 2024
I share the exact same feelings! 🥲
I also rely on the common pattern of shift+drag to select items. I think having the button “Select matching layers” and its shortcut is already sufficient enough.
As much as shift+drag is useful for select matching layers, I think shift+drag to select any item may be a more common use case.
Zoe_Gomez
  • 26 replies
  • March 12, 2024
yeah exactly! the option+command+A is already there, no need for shift+drag too
Cailin
  • March 19, 2024
I also use it to help deselect items I never meant to select and now I can’t do that 😦 Now I have to go and painfully select each individual item because I can’t deselect the items that aren’t meant to be selected
Matthew11
+1 for shift+command+drag ⬆️
