Most interactive components randomly stop working
Christian
This is the second time this has happened to me.
I have spent a ton of time updating my variant components to work in my prototype. Mostly mouse over interactions. I test like crazy as I am building. I test in the component library files and I test in a copy of one of our prototypes. While I am building things are working great. Later in the day, I restart Figma, then go back to the same prototype, and just about all of the interactive components stop working.
I have tried opening up the prototype up in both the desktop (Mac) and the web version of Figma but neither are working.
I tried several restarts and reloading of the prototype but nothing work. Now one thing I did notice, one of my co-workers was in the prototype. After he left all the interactive components started to work again with one exception. All the components that include images (i.e. avatars), the images are not showing up.
Anyone else experiencing this or similar issues?
Booshong
  • March 5, 2021
I’m not sure if this is related, but the interactive components “Playground” project doesn’t work at all for me (I confirmed the checkbox is enabled). If I create an interactive component in a new file, it works fine, but they don’t work at all in the playground file for me.
stv
  • March 8, 2021
Same here - interactive components stopped working. @Christian - were you able to fix it or know of any ways to debug this?
Wei_Qing_Yu
Same problem, sometimes it works, sometimes not
Harun_Alikadic1
Same here, it seems that most of the more complex stuff doesn’t work properly, like autosize or nested components etc. Interactive components are very useful if we can build menus with autosize and reuse trough libraries and nesting components.
Andrew_Chan
Hi all! I’m an engineer on the prototyping team. Thanks for flagging these issues.
@Harun_Alikadic1 - we don’t have full autolayout support yet, but we’re working on it!
@Christian this sounds like a major bug. Do you mind sharing the file with me via DM?
Christian
  • 17 replies
  • March 9, 2021
I think it had something to do with other people on my team that were in the file(s), that were not yet invited to the beta.
To support my suspicion, when I was the only one in the file it started to work again. Also once my team mate was invited to the beta it also started to work with him in the file.
I hope this helps.
Wei_Qing_Yu
Parent and nested components interaction conflicts, if both have interactive components
Tomasz_Gens
I’ve experienced similar problem. I’ve added interactions in my variants and in prototype mode it sometimes works properly but sometimes e.g. buttons on hover seem to be losing their padding.
Sergey_Novoselov
Similar Problem. I have a nested component, for example button. Master component has interactive states (hover, pressed), and child component has different variants (with/without icon, etc.) Sometimes all interactive components stop working and randomly recover. Same situation in other components with similar structure. When interaction works, i see slight change in button padding first time I hover it.
Christian
  • 17 replies
  • March 12, 2021
Again I am experiencing the problem of images not showing up in my prototype. I read in an unrelated Figma help document (regular support) that sometimes images won’t show in prototypes when you have slow internet speeds. My average speed is between 185Mbps and 265Mbps which should be plenty fast. Also, this time when I closed all my Figma files and did a full quit/restart then ran the prototype the images came back.
Christian
  • 17 replies
  • March 23, 2021
And again!
This problem is very random. Today again the images are not showing up. I included a screenshot of the prototype missing the images. And just for context I also included my internet speed at the time of this occurrence.
To fix the problem (for now) I had to close all tabs, then quit and restart.
The same img as above when it is working (post restart).
Corinne_Prainito
Has something happened recently? Literally, all of my Figma interactive components have stopped working properly.
Yulia
  • 39 replies
  • July 12, 2021
+1 In the prototype, when hovering over any component with the “While hovering” effect, the entire prototype freezes and no longer works.
Even restarting the prototype doesn’t work. 😱
Dan15
  • 41 replies
  • December 3, 2021
Yup. All interactive components stopped working after last update. This is why I hate updating any software. Sh*t always breaks because no one QAs properly before releases.
Check your features, people.
Tom20
  • December 14, 2021
I tested back and forth – in my case it’s not random and it doesn’t affect all interactive components. The problem only occurs with components that expand and only if the outer frame has an auto layout.
If you remove the auto layout from the outer frame it works fine. But if you stack elements you still have to combine them in a frame with auto layout, otherwise the expanding components overlap.
Meaning either you draw a fixed frame around the whole layout or you remove the auto layout from the outer frame and then combine all the elements inside in an auto layout.
Dan15
  • 41 replies
  • January 25, 2022
Random jankiness. Works for a while and then simply breaks. Doesn’t matter what you do, can’t make it return to a working state. Irritating.
Michael_Skattebo
I’ve had similar issues. I’ll create a component > test them in prototyping > and then they seem to work fine. A few days later (in some cases, only a few hours later), the same components don’t work in my prototype anymore.
The only way to get them to work again is to delete any instances of the component in a design and re-add them.
Natalie_Peterson1
Same problem as Michael…
Loes
  • August 10, 2023
Damn, been building and rebuilding my prototype because components randomly stopped working only to find out the components are fine, it’s the playground that’s wonky… Please fix playground! It would really help prototyping if it would work!
Jason_Chang2
Any solution for that? QQ’’
I’m still frustrated to reset interaction one by one… and I didn’t change anything.
The dropdown menu click action link disappeared. Sometime it happened when hovering to a component.
