Mixed padding on Autolayout
Lucrecia_Garino
Is there a way to set different paddings inside Auto-layout?
I created with Autolayout the following example, the top one is the one I’m trying to change, the bottom one is the desired result, for that I had to remove Autolayout, set paddings manually, and apply auto-layout again. Then it says mixed, so I think… Am I missing a function?
thanks!
Best answer by Daniel_Bolton_DN
Hi @Lucrecia_Garino, you just need to click on the box with the 3 lines besides the padding field to pop up the menu for specifying custom values for each side:
Example
Daniel_Bolton_DN
Example
Lucrecia_Garino
Oh DUH! I just thought this was for alignment
My UI is so tiny couldn’t see the numbers!
Thanks!
