Merge / Flatten multiple color fills
  • October 18, 2022
  • 928 views
Cristinel_Costachescu
I use custom color swatches with multiple fill colors and blend modes, to produce the final color that I want. And I save these swatches as color styles.
The problem is that mutiple color fills will be saved as-is, and any blend modes will affect the outcome when used on overlapping elements - while instead, I needed to use the final resulting color.
Could you please add a feature to merge/flatten mutiple color fills? I’d understand if it would only work for solid colors - though, conceptually, I can visualize this for gradients and images as well.
The merging should result in a single color fill, with all blend modes and opacities from the upper colors projected onto the bottom-most color.
The bottom-most color gets to keep it’s blend mode and opacity settings - though I would be fine with loosing those, similar to how a color picker would work.
  • January 16, 2023
