Measuring Distance Between Fixed and Scrolling Layers
Phil_Larsen
Seems that I can’t hold shift to measure two layers when one is scrolling and the other is fixed. Not sure why I wouldn’t be able to, but that is something that I find myself needing to do regularly.
Please remove the restriction of comparing those elements!
  • 4873 replies
  • August 28, 2021
  • 4709 replies
  • August 28, 2021
I can’t reproduce this. Maybe you need to also hold Cmd/Ctrl if these objects are nested in other groups/frames? And yes, you don’t hold Shift to measure distances, hold Alt/Opt.
Phil_Larsen
  • 130 replies
  • August 30, 2021
Mmmm, meant to say I was pressing Option. I’ll try some things, doesn’t happen all the time so it feels more like a bug
  • 4873 replies
  • August 30, 2021
Make sure your layers are not overlapped by other layers. Also check if the layers are locked.
Could you share an example of a file in which distance measurement doesn’t work?
  • September 29, 2021
