Ran into a problem.
Updated the master component in the design system, published an update, when switching to a file with layouts, the updates are not applied, the Update icon appears in the right panel, but it does not work, when dragging from assets, the properties options in which were made changes disappear, nothing helps.
If you just copy the instance from the design system and paste it into the desired file, then it is either simply inserted with a white empty square or detached.
Please help to solve this problem.
