I can’t resize sticky notes manually - this would be really nice though. I’m not sure if it’s a bug or a feature, but it feels like a missing Feature.
Yes. Post a Sticky… try to change it.
I can only test it in the browser Mircosoft edge (company policy…)
Mircosoft Edge Version 90.0.818.42
+1
I’m creating a click flow diagram and I wanted to add sticky notes to some steps with questions. The workaround for now is to re-size the entire flow diagram but it is more work to adjust text size later
Hey there At this time, stickies cannot be resized. Stickies have a set width and minimum height. The height will change based on the amount of content you add to them. You can find more info in this Help Center article: Resize, scale, rotate, and flip objects
I’ve recently started to use FigJam and I believe it’s a great tool to rapidly flowchart and communicate ideas to a team. I want to leave a sticky note in a couple of places and many a times they vary in the type of content within them. Can you please allow for a feature to re-size the sticky note?
I’d say having resizable stickies is an essential need for FigJam and basic expectation for users! So I hope Figma have this in their next update of FigJam!
This seems basic and throws off my workflow when transitioning from Miro (well, assessing if it’s possible, little things like this make it hard to convince unfortunately)
+1 to this. Also, it seems like this functionality existed but went away? I noticed a weird behavior if I grouped a sticky note + dot sticker, then tried to resize. The dot sticker would overlap with text. Now I can no longer figure out how to resize at all.
+1. Knowing nothing about Figjam upon the first time I used it, this was also the first thing I tried to do with a sticky. If that’s you, heart Samson’s message. FigPeople™ (aka designers / product people): By making your canvas zoomable and elements scalable to N degrees, you have effectively created a context in which proportions become an important aspect of content design. I don’t think it makes a ton of sense for some objects to scale and others not to.
The notes I (and others) add to our FigJam diagrams very dramatically in the amount of content. I would like to be able to resize sticky notes horizontally. Extensive text makes the notes very long and hard to read and layout.
+1 - yes, one of the reasons we as a team still use Miro instead of Figjam. Resizing of sticky notes and text is really important when you are crowded on a file
+1
I was working with stickies in Figjam just now and I thought it’s a bug from my side.
It would be nice to add the resize functionality to sticky notes.
