Is there a way to identify all unlinked text styles and auto-assign it to an existing/matching text style?
Context
migrating to a client’s figma environment, we’ve imported the text styles but in bringing the design flows over, everything is unlinked. Would like to have everything relinked in the new project.
Thanks!
Hello Rene, you might want to take a look at this plugin. It give you the ability to « SYNC » your Color or Text styles to elements with matching properties.
Sync Style Plugin
Hope it help :v:t2:
Thank you Maxime, I will have a look at this plugin. I appreciate the help! :pray:
@Maxime_Daraize Thank you again for referring me to that plugin, I’ve tested it and it works great for established color styles. Though when I run it for text styles, it tells me x-amount of styles applied but upon inspection the text styles aren’t actually applied. Have you run into this? Maybe a bug in the plugin?
Thanks again!
@Rene_Tan
Hello, thank you for the feedback.
I didn’t run into that issue so far, would you be able to maybe share a link of a « test file » with the specific text styles you tried to apply. It would help me to investigate and resolve the issue.
Thanks again
P.S.
If you can’t share a link, could you share the properties of the text styles
Thanks @Maxime_Daraize :pray:
For context, I’ve pulled a sample set of typestyles in, and then I’ve copied over a component that should be leveraging a few of those styles.
Funny enough when I run it, it is not identifying any instances to apply the styles at all. Here is a link to my test project, thanks again!
No worries & thank you for the link :ok_hand:
So I had the same issue, when I tried to use to plugin or simply associate one of the text style to a text element manually. (Which is odd).
What I found, is that the font-family and the font-style were missing (not installed).
I think this is why we run into that issue.
When I changed to font-family& the font-style. I was able to use the plugin & associate style to element without any issue.
Maybe, if you have those fonts, tried to install them so Figma can recognize them.
See images below.
Screen Shot 2022-08-19 at 10.23.33 AM
Screen Shot 2022-08-19 at 10.24.14 AM
Gotcha, I will try to see if I can find a way to install them locally as I’m using adobe’s cloud type library,
One thing I’ve observed though was that if I let’s say create a new unlinked text field with the same properties locally, or if I duplicate the instance that was assigned a style then detach it, the plugin works to match/reassign as expected – so I’m not sure how that plays with the cloud fonts but will keep you updated!
Strange, so it make some time to see if I can get the fonts locally for Museo. But I tried it with a font family I know I have installed locally, Gotham. I ran the plugin, it says x number of styles were applied but when I click those text fields they aren’t truly assigned.
Hey, thanks again for your feedback.
So after few tests, I realize that it dosent work properly with locally installed font. My guess is the plugin dosent recognize font outside from the fronts included in Figma.
I’ll try to figure out a way to make this work. Thank you again for discovering this bug.
I’ll keep you in touch,
Thank you so much for the support, hopefully we can find a solution @Maxime_Daraize! :pray::100:
