Is "after delay... scroll to" possible? It's an option, but targets are greyed out
  • January 29, 2021
  • 5 replies
  • 2153 views
Patrick_Morgan
I’ve got a use case where I want the screen to scroll to a section on load. In other words I want to use “after delay”… then “scroll to” a particular section.
“Scroll to” is a selectable option under “after delay”, but the targets are greyed out and I can’t figure out why. The root frame has overflow turned on and set to vertical scrolling. Is there something I’m missing or is this just not currently possible?
Best answer by Gleb
This looks like a bug, I have the same behavior. And not only with After Delay, but all triggers. Send the bug report and link to the file to Figma support via the support request form or support@figma.com.
As a workaround, you can always drag the prototyping connection to the necessary block manually instead of selecting this item from the list.
  • 4710 replies
  • January 29, 2021
Patrick_Morgan
Ah nice one @Gleb, good workaround.
Yep definitely looks like a bug - I’ll submit a report.
Mr.Biscuit
  • 109 replies
  • January 29, 2021
аххахаха 🤣 Figma will make you smarter everyday.
Greg_Saxton
I am having the same issue. In surprised that it’s been over a year since this was reported and it has not been fixed
bombadillo
  • 25 replies
  • December 16, 2022
I am having this issue. I’ve never had the problem before using frames and autolayout. I finally started using frames and autolayout, and now jump links are grayed out for me. How has this not been fixed when someone brought this up almost 2 years ago?!
Submitting a bug myself too, but that never seems to fix anything in time.
I may just put a random blank element over the frames to be able to jump down.
