When I create a slideshow with frames it goes to left and right thanks to smart animate.
But interactive component ignores the second drag interaction.
Demo
Demo
I have encountered the exact same problem. I think there is a solution to that with usage of mask. I’ll get back to you with a solution if I’ll be able to resolve that.
Still though, it would nice and very intuitive to have it work as presented.
Did you ever find a solution to this? I’m having a similar issue with it not respecting the ability to drag backwards and getting me stuck between two slides like that.
Hey all! Since it is very difficult to determine the cause and guess anything without having access to the file, I suggest you look at the official example of such an interactive component here:
Thank you! I was actually able to figure it out after a lot of trial and error. It appears I needed to apply the drag to the slide directly and not just that whole variant.
Hey did you make it work? I was actually giving it a try with the masks but still fails.
Beside the fact that it starts dragging everywhere
Hey @Sage_Abplanalp. I am still running into this issue. I have added the drag directly the content panel (think of the variant containing a tab bar and content) not the whole variant frame but it still doesn’t work and defaults to the first drag in the list. Any ideas? Thanks.
@Rhys6 Are you making sure to apply the drag to the slide content itself? If it’s part of the variant frame not the content itself it can still get stuck.
