Christoffer_Hedberg
Nov 29, 2024 9:37 AM UTC
Image export (REST) intermittently disregards variable mode
In a certain scenario, only parts of the exported images use the correct variable mode.
Given this simple variable setup in a variable library file:
And this simple component in a component library file, utilizing the variables from the variable library file:
When I pull in the component from the component library file into the variable library file and set the page variable mode to “dark” the component looks like this in the file:
But when exported through the REST api, it looks like this:
Exporting it through the UI works as expected. This bug is seen for both svg and png.
How to reproduce:
  • Create a variable library file that supports two modes (light/dark) and publish them.
  • In a separate file, create a component using variables from the variable library file and publish it.
  • Import component onto page in the variable library file
  • Set entire page to alternative mode (dark)
  • Export image using REST api (/getImage)
  • See result.
