iframe embed remove UI
  • September 12, 2024
  • 746 views
Mara_Varady1
Hello,
I am currently trying to embed an iframe on a Sharepoint site and I want to remove the Figma UI. I have previously been able to do this by simply amending the url with
%26hide-ui%3D1
but now this doesn’t work. I have noticed that the entire iframe embed code is different now. like I compared the code I have for a prototype that is currently live and has the UI removed, but when I compare it with the embedded code that Figma gives me for that same prototype now, its completely different.
Please help! TIA
  • 4873 replies
  • October 1, 2024
If your embed code contains embed.figma.com instead of www.figma.com, it means that Figma Embed KIT 2.0 is used. Although the hide-ui parameter is not specified in the documentation, you can still use it. Just use &hide-ui=true or &hide-ui=1 instead of the encoded string %26hide-ui%3D1. Or use the documented query parameters.
Learn more on Figma Developers:
https://www.figma.com/developers/embed#embed-a-figma-prototype
