I can't open because WEBGL isn't supported?
Karl_Rydfors
How do I access the project when this comes up?
Uh oh… we can’t open that file
We can’t open this file because WebGL isn’t supported, or is disabled, in your browser. If your browser supports WebGL, check out this help article to find out how to enable it.
  • 4873 replies
  • June 4, 2021
Does it show up in the Figma Desktop app and / or in the browser?
Pablo
  • November 1, 2021
I have same problem. I am in desktop, with firefox version 93.0 with Ubuntu SO
¿any idea?
  • 4873 replies
  • November 1, 2021
Try enabling hardware acceleration and enabling WebGL.
The article below describes how to disable these settings, but you need to enable them.
https://support.mozilla.org/en-US/kb/upgrade-graphics-drivers-use-hardware-acceleration#w_turning-off-hardware-acceleration
Pablo
  • November 2, 2021
Thanks for to reply.
Bu I already had that setup correctly.
And webgl.disabled I have with false value
  • 4873 replies
  • November 2, 2021
You can also try updating the video card driver. If this doesn’t help, it is better to contact support.
Terence
  • 9 replies
  • May 27, 2022
This started happening to me today and I have been using Firefox with Figma for 3+ years
Terence
  • 9 replies
  • May 27, 2022
Some how the settings in the browser changed while the computer was idle overnight. Weird.
This page explains how to change your settings
Human Support
Phanuel_Mutuma
Managed to fix the error with a restart.
Dominik_Bat
Restarting my PC helped too.
Ricardo15
  • December 21, 2022
Restaring the computer fixed the problem for me.
Nomiki
  • January 21, 2023
Hi All
№1. Check your browsers for supports WebGL2 (and default, and all)
For example here: https://get.webgl.org/webgl2/
№2. If Chrome not rendering, go to adress: “chrome://flags”
Find stroke: “Choose ANGLE graphics backend” and find “OpenGL” then button “Relaunch”
№3. After that check №1 again. If work on test webgl supporting — restart Figma app and all ok.
In my situation №2 help well done with Chrome, But default browser was and now Firefox in system ))
Nik_Fewel
  • January 23, 2023
If you aren’t able to run WebGL in Chrome, make sure that you update to the most recent version of Chrome . If you are using the most recent version of Chrome and can’t access WebGL content, make sure that hardware acceleration is enabled in your Chrome settings.
Disable your “Intel UHD 730” driver from device manager and restart your PC, it will resolve your error, because the error with “Intel UHD 730” this particular integrated graphic card so if you disable your graphic card the glitch is not working anymore.
  • July 19, 2023
Enabling hardware acceleration on Chrome
Had this problem too, but after a quick panic attack I found out updating your browser helps. Go to the three dots in the top right > help > about google chrome and then there should be an update fuction.
Otherwise, plan B would be using any other browser and you should be able to just open it there.
Alexander_Engl1
For me this just came out of nothing, I was working for an hour on Figma, no updates on Browser or anything. Suddenly the screen went black and this issue came up. Windows 11- Chrome, all last versions
Gayani_S
  • 2133 replies
  • February 19, 2024
Hey @Alexander_Engl1, did you also see the following error?
Can you check if you see the same error in the desktop app? Please go to https://get.webgl.org/ and check if it shows WebGL is enabled? If you do not see a spinning cube you can enable WebGL by following the link on that page that says ‘visit the support site for your browser.’
If you see the spinning cube there, can you go to https://webglreport.com/ and take a screenshot of both tabs for us (WebGL 1 & 2). Also let me know what Browser you have tested in?
Technical Troubleshooting Tips and Configure your browser for Figma cover our requirements in more depth.
Here are the links to our Help Center article:
Figma Learn - Help Center
Please let me know if helps!
Just upgrade your browser it will resolve.
Michal_Kuczek
Enabling this flag: #enable-webgl-draft-extensions solved the problem for me.
Mila_G
  • 7 replies
  • April 5, 2024
This issue still is not solved for me. I have tried turning ON or OFF every setting specified across multiple post, Ive cleared the cache, hardware acceleration will NOT stay turned on, Ive done the webgl test and it says my 2021 M1 is compatible but its not turned on. Im on the latest chrome, Figma, and I just downloaded Sonoma. What’s worse, because I cannot turn webgl on I cant open any files to get to the setting that will allow links to only open in the app instead of the browser. Im completely stuck unless I use a different browser which I dont want to do. These and Abobe XD links randomly stopped working on chrome about a year ago. WHAT is the deal!?
Gayani_S
  • 2133 replies
  • April 10, 2024
Hey @Mila_G, sorry to hear that the issue has not been solved for you. I’ve just created a support ticket on your behalf. Your ticket number is #971302, for reference. Our technical quality team can assist you further with your issue. Appreciate your patience in the meantime!
Thank you,
Gayani
Mila_G
  • 7 replies
  • April 30, 2024
Thanks.
I did receive help for this issue (thanks for that) but it resulted in no results. Seems to be a chrome issue.
chrome://settings
Settings > System > Use hardware acceleration when available > Enable > Restart
설정 > 시스템 > 가능한 경우 그래픽 가속 사용 > 활성화 > 재시작
Source Chrome, with Safari method : https://support.biodigital.com/hc/en-us/articles/218322977-How-to-turn-on-WebGL-in-my-browser
Yash singh
  • January 21, 2025
unable to create matka apps 🙁
Celine_
  • 3688 replies
  • January 21, 2025
Hey everyone,
As ​@Gayani_S mentioned, please check if you see the same error in the desktop app. Please go to https://get.webgl.org/ and check if it shows WebGL is enabled. If you do not see a spinning cube you can enable WebGL by following the link on that page that says ‘visit the support site for your browser.’
To cover some basics, it's also important to ensure your browser meets certain requirements for optimal performance. Here are the steps to prepare your browser:
More details in our guide: How do I configure my browser of Figma?
For others, who are having specific trouble with WebGL on Chrome, our internal team is aware of this issue. Please follow these instructions from our technical quality team if the issue still persists (Thank you ​@Mila_G for reaching out to our support team directly about it!):
As this doesn't seem like a hardware issue or related to Figma or Adobe, but it does seem related to a browser configuration in Chrome that's somehow overriding and toggling off your WebGL. Looking in Google's forums, it seems like others have reported similar issues, so it might be best to reach out to their support for assistance as they'd be better equipped to troubleshoot.
It might be helpful to capture your GPU report after enabling Override software rendering list and GPU rasterization for their reference. Please remember to restart Chrome so the changes take effect.
In the meantime, we’d recommend using another browser moving forward.
For others who are still having issues and need further investigation, please contact our support team directly by filling out this form here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
To help our team investigate, please include the following information:
  • Your Figma account email address
  • Your graphics card information, (For example, for Google Chrome, please chrome://gpu in Chrome and save the page as "Webpage, Complete" format using Control+S on Windows (Command+S on macOS).)
  • Your video clip / screenshot when you encounter the issue
  • console log capturing the issue
This will help our team to better investigate your specific issue. Thank you!
