How to "un-component"?
  • August 2, 2024
  • 4 replies
  • 7882 views
Hello,
I create complex object, then I “group”, and “create component”.
I want to modify the component, and so to “un-component” it.
How to, because as for “group & ungroup”, there is “create component” but not “un-component” menu ?
Best regards
ksn
  • 1729 replies
  • August 5, 2024
Hi @Francois_PION-DRANCY - short answer is that there isn’t an automatic way to “uncomponent” a main component.
You can, however, “undo” a component by:
One other suggestion – there’s also a plugin called “Uncomponent”, which also undoes main components: https://www.figma.com/community/plugin/931839698966723759
Just a note if you decide to go the plugin route: the above plugin was created by a Community members, and not Figma. If you run into any issues with using the plugin, you’ll need to reach out to the plugin creator directly (their contact info can be located at the bottom right of the plugin page).
Hope this helps!
Thank you for these proposals.
My goal was in fact to modify the component, and that was not very clear to me (as beginner).
But I have discovered that I can put a new element IN the component (by drag&drop in its area), and if I want to increase its size, I need to use ctrl+mouse on the component border.
It is enough for me.
The solution with the deletion of original component imply I loose all the links between instances and component.
Best regards.
cstrich
  • September 20, 2024
this is pretty idiotic, why not just ad the “uncomponent” feature on Figma, to be “such an trendy programe” it should have it…
  • 4911 replies
Thanks for the feedback!
Feel free to add your feedback for the team and vote here:
