How to remove an imported component?
  • April 20, 2023
  • 449 views
step34
Hi,
When using " importComponentSetByKeyAsync" it imports the ComponentSetNode into memory and I can use it to create instances via my plugin.
The issue I have is that the Node is first added to the memory, but there doesn’t seem to be a way to remove it from memory if I want to. The .remove() method only works on nodes that reside in the document.
Does anyone know if there is a way to clear the remote Nodes from memory?
Best answer by tank666
The only way to clear the memory is to reload the file tab.
  • 4873 replies
  • April 20, 2023
