How to drag svg from figma plugin and drop to figma canvas?
Prerana_Das
Drag svg from Figma plugin and drop to Figma file.
Like they did https://www.figma.com/community/plugin/884531262241804656/Drag-%26-Drop
I’m wanna develop this type of feature in my plugin.
Best answer by tank666
Since you are using Typescript, you need to respect its syntax and also return false:
figma.on('drop', (event: DropEvent) => {
    // Your code
    return false
Also add a condition for line 9 (on which you supposedly have an error) as in the example I gave you a link to:
github.com
Avokadomos
  • 377 replies
  • September 22, 2022
Is this a question? 🤔
Prerana_Das
  • 9 replies
sorry yeah
Avokadomos
  • 377 replies
Can you explain further? This depends heavily on the plugin that you’re using.
Prerana_Das
  • 9 replies
Please look back at my question again. And actually, Figma not allowing to create SVG Instance directly.
I got this error “‘postMessage’ on ‘Window’: SVGSVGElement object could not be cloned.”
in my plugin.
  • 4862 replies
Use the “Drop” event in code.js.
Check out the following official examples:
Prerana_Das
  • 9 replies
I’m not sure why but when I try to use figma.on(‘drop’,…) it’s throwing errors
  • 4862 replies
I don’t see any errors here. But you probably need to update plugin typings.
GitHub
Prerana_Das
  • 9 replies
I had update plugin typings but still
  • 4862 replies
    // Your code
    return false
github.com
Prerana_Das
  • 9 replies
  • September 25, 2022
Thank you so much for your help. It’s working now. But one typescript error still showing
if (node.appendChild) {
   node.appendChild(newNode);
Showing this “Property ‘appendChild’ does not exist on type 'DocumentNode | PageNode | SliceNode | FrameNode… etc”
  • 4862 replies
This condition is just written in order to bypass the error you indicated.
Prerana_Das
  • 9 replies
Okay thank you
