How to delete a file from the 'shared files' tab in Figma
tessav7
Hi there 👋 I want to clear out my shared files page in Figma. I was given ownership of this file and I have duplicated it into my drafts but when I try to delete the shared file I get this message.
Thanks!
I am also stuck there, I was able to leave some of the files where I was explicitly added, but the files with “anyone with link” permission I am not able to leave them.
Sergei_Sadowskii
Hi. I have the same issue. What’s gonna happen if I delete a file? Will other people lose access to it or not? Or this button delets a file just from my Figma account?
ksn
  • 1688 replies
  • November 29, 2023
Hey Tessa - in your instance, are you trying to delete the original file that was a shared file? When you say you were given ownership, was it specifically transferred ownership? it may be that you were given shared edit access, and you can’t remove it because it’s technically not your file.
For Swapnil - Did you inherit access to the file? If you have inherited access to the file via a project or team, you need to leave that project or team to remove your access.
For Sergei – are you talking about deleting a file that you own, and have shared access with ‌other people? Deleting a file will remove the file for all collaborators, not just yourself.
I’d recommend everyone take a look at these help pages:
https://help.figma.com/hc/en-us/articles/360047512294-Delete-and-restore-files
https://help.figma.com/hc/en-us/articles/4420221688343-Leave-a-file-or-prototype
  • January 2, 2024
Has anyone found a solution to this problem yet? None of the solutions provided seem to work. If someone shares a file with you with the link set to “anyone with the link,” the file will remain in your “Shared files” tab even if you leave the file. Is there any way to remove the file from the “Shared files” tab?
Eric444
  • March 22, 2024
Any word on this?
If someone has shared a file with you, and you’d like to exit the file so it doesn’t appear anywhere without deleting it for yourself or anybody else, this link explains how it’s done: https://help.figma.com/hc/en-us/articles/4420221688343-Leave-a-file-or-prototype
Basically you right-click on the file and select “Share”. From there, find your name in the list and tap the little drop down menu to the right of it. Choose the “Leave” option, and you’re done!
Here is how it’s done: https://help.figma.com/hc/en-us/articles/4420221688343-Leave-a-file-or-prototype
Check my comment at the bottom of this thread for a more detailed explanation.
dimapoltavets
I did the same thing, went into the file and in the ‘share’ tab found myself and clicked ‘leave,’ but the file still remained. Did your file get successfully deleted?
  • August 16, 2024
I have the same issue. I have left the files and prototypes but they still appear in my shared files. I am not the owner. How do I get rid of them ?
Thx
Celine_
  • 3676 replies
  • August 19, 2024
Hi there! At the moment, there isn’t a way to remove files from your “Shared files” tab, in the “Recents” navigation page, I’m afraid.
However, I can see how what you’re suggesting can be useful for other users and I’ve noted it for our Product team. I can’t guarantee anything on our end, but I can give it some visibility here. Feel also free to vote up the idea requested by others in the community (this will help us to gauge the overall interest in the community, and our Product Managers also check the forums regularly). Thank you! :
Michal_Rakovsky
I’m also struggling with this!
Vlada2
  • October 1, 2024
Hi there!
Indeed, if you use Leave via Share link, the file still remains in Shared files. But you can ask file owner to help you.
The file can be deleted from Shared files if you follow this scheme:
  1. The owner of the file will set the setting using the Share button - Anyone - Can edit Then owner will resend the link to you.
  2. You need to follow the link. Then close the window with this link.
  3. Then, the owner of the file, using the Share button, Remove you from the list (a warning window should appear saying “account name” will immediately lose direct access to this file if you continue")
    4.Now you can see, that file has disappeared from Shared files file in your account
This also won’t work if the Owner just Remove you from list. You need him to change the access settings again and send you the link in a new way.
