Highlight invalid assets better
Apolline
When one of my design system assets is invalid, it’s barely visible at the moment of publishing that it’s invalid and it will usually take me a few minutes to notice what’s wrong since it doesn’t look any different from usual publishing at first glance.
Having a warning that’s highlighted and look different from usual on the publishing modal would help a lot.
Thank you!
Apolline
  • 64 replies
  • February 28, 2025
Once again had an issue with this, but that was even worse than usual because Figma decided to “fix” the conflict by itself before I could understand what happened by splitting the variant from the component, completely breaking the logic I made before.
Apolline
  • 64 replies
  • February 28, 2025
Whatever you did to “fix” my component, if it’s a new update, please revert it. I cant get my component to update properly at all now.
Expected properties from the design system
Same component in my file using the design system
(All put to active for testing purposes because I’ve struggling with this for an hour now)
Apolline
  • 64 replies
  • February 28, 2025
