Hexagon sides are not even
  • May 15, 2023
  • 2667 views
Filanco
I was designing a hexagon-based logo recently and came to horrid realisation: 6-sided polygon in Figma IS NOT a perfect hexagon, where all sides should be equal and angles 120 degrees. Everything is slightly off.
Take a look: black line is a perfect hexagon and the grey one is a default 6-sided shape from Figma
Best answer by Gleb
Where did you get this hexagon from? Here is a freshly-created hexagon in Figma I just made. I put the lines on manually for measurement. As you can see the angle is perfect (slightly off because of manual placement of the line) and the two lines are exactly the same size. Maybe you didn’t hold Shift while creating or resizing the polygon?
  • May 15, 2023
Denis_Githuku
You could try to use a polygon by starting on a triangle. Vary the corner count.
