Help to set an image value in variables?
I need set value for assets in my design system, ex:
My logo dark mode vs light mode, the brand asset are different for the color scheme.
The options available are:
  • Color
  • Number
  • String
  • Boolean
I try insert the URL from image value in string, but I dont have success to retrieve value and set for background.
Anyone have a idea to resolve this? :exploding_head:
Anynone can help me?
Just played with something similar. Tried to change the logotype of our multibrand design. In our header component i put both logotypes and controls them with booleans properties. Then I set the boolean values from two booleans variables.
Maybe not the best solutions since it will create more layers in the component?
This wasn’t obvious from the UI but I discovered it in the Playground File.
You can bind a string variable to a variant property, which means if you have a component with each image as a variant, you can use a variable to switch between them
Tks for help!
I go try this, tnks :wink:
I can’t get this to work. Do you have to name the modes the same as the variants?
For example type=
