Go to component - with a return option
most of the times when i want to click on go to component, I just want to have a look and then come back (to locate it, for instance).
but then I need to find where I was before in the file. I want to have the option to just have a glimpse on it with the option to return, OR edit it.
When you ‘Go to main component’, you should see this button at the bottom of your screen.
When you select anything else, e.g. a nested layer in case you want to do some editing, this button disappears. But you can select it again (the main component) and the ‘Return to instance’ button will reappear.
Hello,
I work for a company that would greatly benefit from a button that displays in the layers panel on individual layers that would jump to that component on the screen. We often find ourselves struggling to find our specific components or frames in our large projects. If there was a way to click on a layer and center that selection on the screen it would be a big help and time saver.
@Peter_Rattin does double clicking the icon for the layer by chance accomplish what you’re looking for?
