Fixed position when scrolling doesn't apply to daugther components (and it's impossible to turn it on at daughter instance)
  • March 31, 2021
  • 386 views
Victor_Hugo1
After testing my prototype with detached instances I began polishing it up using daughters of main components I have created, just to make my life easier when adjusting the UI on the go.
I noticed a component I designed wasn’t behaving as intended (and as previously tested). I corrected the settings, including the “fix position when scrolling” setting, making it exactly equal as the version tested, but again, it failed. I then realised this particular setting wasn’t being applied to the daughter instance!
I tried everything I could, but enabling it at the daughter instance seems to be impossible. Can anyone help me out?
  • 4710 replies
  • March 31, 2021
It is not possible, this option is not supported in components. You can vote for this suggestion: Request: Fix-position for components
