FIXED: Bug with Multi select / edit text and library font styles
Hi team,
With the new multi select/edit text, when using this function across different breakpoints the fonts styles are being replacedto match the edited field.
If the edit prompt field is in a desktop frame it will replace our mobile frame with the same desktop font styling.
Is there a way to make edits to the copy without the styling being replaced?
Hey Paul! Thank you for your feedback. This is intended for now, but we will pass your feedback to the team for improvement!
Thanks, @Celine_Figma appreciate the response. Would you happen to have a shareable roadmap of what the intention will be in the future?
Also, can you suggest any temporary workarounds after a multi-select-edit to prevent font styling changes without the need to manually change the text fields for the mobile breakpoints back to the mobile-specific font style?
Thanks
Paul
Hi Paul! To be transparent, the team is working on it now to implement a fix, although it is an “intended” behaviour - while I can’t share any specific ETA for the moment. Stay tuned, and thanks for your patience in the meantime! :pray:
Thanks for your transparency @Celine_Figma. I’ll keep an eye out for the fix.
Hi @Celine_Figma it looks like a fix was deployed and the multi-edit is working without changing the font style.
Thanks for the support!
Hey Paul!
Yes, I confirm a fix has been deployed. Thank you for following up!
