Fix Position when scrolling causes frames to disappear
Martyn
I am trying to freeze a menu at the bottom of the display. When I choose to fix position when scrolling it disappears from view on figma mirror or in prototype mode.
I’ve tried messing with the constraints even attempted to fix it in the middle of the screen just to see if that would work but as soon as I check that box it disappears.
Best answer by Gleb
If you set constraints correctly, nothing will disappear. Constraints control which side of the screen is used when fixing the content relative to it. So if your item is somewhere at the bottom of the long scrolling list (y = 1500 for example) and you set its constraints to Top — it will be fixed relative to the top, at y = 1500, which is outside of the visible screen.
  • 4873 replies
  • April 15, 2021
Place the menu item at the bottom of the frame (where your content ends), in the constraints properties select “Bottom”.
Martyn
  • April 15, 2021
Constraints were set to the bottom, still disappeared. There’s a few spectrum threads listing this bug. I tried everything I could find on these forums for 2 hours. To fix it I rebooted the mac and reinstalled figma, then it worked. No idea why but that fixed it
  • 4708 replies
  • April 25, 2021
Can you share the file link?
Brian5
  • May 27, 2021
Did you find a solution? i am experiencing the same
  • 4708 replies
  • May 28, 2021
Martyn
  • May 28, 2021
I can confirm it was a bug. I copied and pasted the frame into another file and it worked fine. From there I migrated the whole prototype into a new file and it worked seemlessly
Fabian_Stuckrath
I have the disappearing layer problem too. My Problem is, that Figma automatically places sticky elements above scroll elements. A scrollable overlay in the front seems to be impossible to do.
Lara_Osborne
This explanation helped me tremendously. Thank you so much.
Maisura
  • September 10, 2021
Thanks! This helped!
Nabil1
  • September 13, 2021
Just came across the same problem. Instead of moving everything to a new file, I just closed Figma and opened it again. Fixed the problem.
  • 4791 replies
Hey @Nabil1,
That definitely seems strange. If you come across this issue again, please let us know.
  • 4708 replies
  • October 30, 2021
This topic was automatically closed after 19 hours. New replies are no longer allowed.
