findAllWithCriteria Instances bug
Graham_Paterson
Summary
Running findAllWithCriteria({types : ['INSTANCE']}) and then accessing properties on the returned instances causes subsequent calls to return ±5x the amount of results.
Additional Info
  • This doesn’t seem to happen on other node types, just INSTANCE nodes
  • skipInvisibleChildren is set to false (running with it on does the same thing, just less)
  • Running a custom traversal function returns the 5x amount.
  • Accessing the id property doesn’t seem to trigger the amount increase.
  • The instances in the large array seem to have unique ids.
  • There’s also a small difference between calling it once and second time but remains consistent after the second call.
Any info/help would be appreciated.
