Fill another part of vector
Tariq1
Hi All,
I am trying to fill the background of this vector white but I can’t seem to do it. I can only fill the mask shape but how do I click the background and fill that white as it I want it White with the black strokes.
Thanks
  • Please write your topic title as a question (if possible) — this helps with search
  • Give as much context as possible (details, screenshots, etc.) — this helps the community help you
  • Make sure to remove these points before posting. 🙂
Adam
  • 47 replies
  • May 17, 2021
A single vector can only be a single color. Make separate vectors for different colors.
Ember
  • 6 replies
  • May 18, 2021
i agree 1 layer 1 colour. so you would have to choose your work flow.
either you can layer each colour based on the 1st layer you have here and then build it up (ex duplicate, delete nodes, close loop, etc).
or you can do it like a jigsaw puzzle. but the jigsaw way is a bit worry some because if the notes and anchors are on grid constrain then when you resize some points will miss the mark and looks off. this will create an empty space as well.
Daelij
  • January 12, 2023
use the Edit Object button in the toolbar to quickly enter vector edit mode. You can also double-click, or use Enter.
Once in edit mode, click “B” on your keyboard. this will select the “paint bucket”, allowing you to color-in the closed shapes separately.
Hope this helps.
  • November 9, 2023
Bless up… this tip still works even now! Thanks =)
Cameron_Remesz
Not all heroes wear capes
Joanna6
  • 4 replies
  • April 23, 2024
Thank you Daelij, I almost teared up from unbelief and happiness.
