Figma plugin check current file size
Pedro8
Is it any figma function to get the file size at a given moment in time?
This question comes related to the fact that I would like to check, by plugin code, the size of the current figma file before and after detaching some components.
Dhakshnamoorthy_L
To see the file size of a figma file:
Open the respective figma file. There go to,
Left top Figma Icon (or main menu) > View > Resource use.
Nehmat_Gereige1
This is a fantastic tip. Thank you. I had no clue this existed natively in Figma and really needed to discover what is bloating the size of our files.
EmberN
  • 8 replies
  • July 25, 2024
same problem here again! the Resource use is not here anymore. So is there a way to do this or a plugin? i just want to see the components and what their sizes are before exporting T_T
  • 4912 replies
  • July 29, 2024
Hey @EmberN, sorry for the trouble!
Depending on your OS, you can use the Quick actions menu (Command + / (Mac) or Control + / (Windows). Then, search Memory usage:
Clicking on Memory usage from Quick actions will bring up Memory usage within your Layers panel, and you can click Manage memory to see a full breakdown:
RobKovacs
  • 5 replies
  • November 13, 2024
@dvaliao Is there an equivalent command or menu option for FigJam files? Memory usage doesn’t show up in the Quick actions menu in FigJam 😢
ksn
  • 1735 replies
  • November 14, 2024
Heyo @RobKovacs! Jumping in – so there’s something similar in FigJam that may cover what you need.
One thing first: when I reviewed the suggestion I make below, I noticed that there was some buggy behavior with the information being hidden behind the floating UI3 panel, which I’ve already gotten a bug ticket filed for. Wanted to give you a heads up just in case you run into this issue.
Try the following:
Open Main Menu > View > Resource use
Would this work for you?
