Hi, I know we can get all the local styles using the plugin api Figma.getLocalPaintStyles(). But is there any API to update or add localStyles? Basically I want to get all the colors from the selected frames using Figma.getSelectionColors(). And then add the colors as variables or color styles. How do I add/update variables or colorstyles using any plugin API?
Thanks. 2 more questions:
- Is there any similar plugin API to create local style as well?
- Can I replace a specific color fill with the corresponding variable/localStyle with the same color hexcode or rgb value using a plugin API?
First link
Okay. I think I found it. createPaintStyle(). Thanks
Yes, the link goes to createPaintStyle
method.
Yes, absolutely. Just set the fillStyleId or stroke whatever other field you need.
Thank you
