Dale
February 16, 2021
Export Layout Grid in PDF
  • February 16, 2021
  • 11 replies
  • 19785 views
Hi all,
I may be missing something really simple but I’m looking to include layout grids when I export to a PDF. Right not the UI shows but no underlying layout grids, is this an option?
Power Member
February 16, 2021
You need to use a plugin that will turn your layout grid into rectangles which will be visible on export. This plugins is Layout Grid Visualizer by @Tom_Lowry:
Figma
Neil_Nichols_II
February 16, 2021
The only problem with that plugin is that it doesn’t work for baseline grids/grids set to auto 🥲
Bryan_Funk
January 18, 2022
That plugin does not work. Can’t believe I spent all that time making these things perfect ofr handoff only to not be able to export them.
Power Member
January 18, 2022
Developers can inspect layout grids right in Figma, there is no need to export them.
aharito
November 15, 2022
Sometimes it is necessary to show UI elements to the customer exactly in the layout grid, so the ability to include the grid in the export is very necessary.
Power Member
November 15, 2022
That’s why there is a plugin above for these rare scenarios.
aharito
November 16, 2022
Unfortunately, this plugin does not work.
Power Member
November 16, 2022
Works fine for me. Try reaching out to the plugin developer and tell them what specifically is not working for you.
DIEGO_MANTILLA
November 2, 2023
Thank you very much for recommending that Gled plugin, it helped me a lot, it worked well for me, I had to adjust the color and percentages a little but it looks perfectly in my PDF.
Mirian_Berrocal
November 14, 2023
The plugin works, unless you choose “Auto” in Count (=
