Levano
June 26, 2023
Dynamically change modes through prototyping interactions
Currently it’s not possible to dynamically set or assign mode variables to a frame or a document. This would be incredibly helpful when it comes to user settings, like change a theme or language, for example.
When prototyping, dynamically setting a mode variable like systemTheme or systemLanguage could then be done through user interactions like clicking a button, to simulate many real-life use cases.
William_Attaway
July 10, 2023
yeah really hope this gets added also. Can change variables, but changing modes seem like missing link. I have to do it variable by variable, or create component variations for each frame of modes.
AliciaC
I want to use a similar approach to create mouse over effects on rows in a table.
glenn.lee
August 19, 2023
+100 to this. For an interaction that only loads variable data of different modes into the same component, it would seriously cut down on the number of frames.
Jochen2
I was just looking for such a possibility. Yes, a prototype with, say, 30 screens, to be switchable from light mode to dark mode in flight would necessitate only those 30 screens. Right now it needs a duplicate of each one of those, so 60. Furthermore, all edits have to be applied twice to those screens in both modes.
Light mode, dark mode and a second language version? Make that 120 screens with each edit performed 4 times.
So, yeah, a long way to cutting number of screens/frames and the drudgery of all those repetitive edits. 🙂
Lachlan1
Being able to change the modes of a component upon interaction just makes so much sense and would make my prototypes so much cleaner and easier to configure.
Oh well, I guess I get to choose between having 5x the component states, 5x the frames, or manually configuring 4 variables on 20+ different interactions instead. (psst. Hey Figma, letting us copy actions between interactions might help with that last one!)
Still, I love the new prototyping functionality. Just can’t wait for them to add more / fix more quality-of-life issues!
Yitty_Falk
+1! This can be such a great way to combine multiple variables into a “set” and change all with one “Set Variable” action
JonM
This would be awesome!
Jaron_Lugtenburg
October 9, 2023
+1 Definitely be needing this, making it much more efficient. Now you need to add like a million change variable actions which could simply be done with one mode switch.
Shukri_Brewer
I have configured read/write modes for my form components. In read-only mode, the field and some controller icons/buttons are hidden.
Currently I have an “Edit” button that links to a different frame where are the same components are, but the frame is in the “Edit” mode. Would be nice to achieve that with an action in the prototype.
Sarah_Lauchli
November 2, 2023
This would be incredibly helpful for reducing the number of components I need to use for button state changes (hover, click, etc.)
