halkiona
Jun 30, 2023 10:42 AM UTC
Drag direction up and down using variables and conditionals
Hi,
I’m trying to create a temperature picker and recent variables launch hugely simplified the process. I previously has to create a variant for each temperature. I just created a conditional to increase and decrease the temperature. However, I can still only drag the value in one direction only, in this case increase only.
I added two drag interactions one for toggling the temperature up and one for toggling it down but the second one doesn’t work. Is there a way to set drag direction when using conditionals? If anyone has an idea, please let me know.
Jun 30, 2023 12:19 PM UTC
To be able to drag in different directions, your component must have a draggable object that must extend beyond the component’s bounds.
Just follow this guide:
  1. Create a number variable;
  2. Create a component set containing 2 variants (Minus, Plus);
  3. Apply the variable from step 1 to the text layer of both variants;
  4. Create a rectangle that is 3px higher than your variant’s height;
  5. Put it in each variant;
  6. Set this rectangle to the following coordinates:
    • Minus variant:
      X = 0, Y = -1;
    • Plus variant:
      X = 0, Y = -2;
  7. Add 2 interactions to the rectangles with the “On drag” trigger:
    • Minus variant:
      On drag 1 › Set variable to decrease;
      On drag 2 › Set variable to increase and Change to Plus variant;
    • Plus variant:
      On drag 1 › Set variable to decrease and Change to Minus variant;
      On drag 2 › Set variable to increase.
halkiona
halkionaAuthor
Jul 3, 2023 9:58 AM UTC
Thanks @tank666 for sharing this idea. It works but it’s not exactly what I’m looking for.
When I drag up for example, the whole component duplicates and moves up change to a minus variant.
I even tried to create a component using the temperatures box only but then it doesn’t work for some reason. The component needs to be able to collapse and expand as well. I found that conditionals inside components when I change the variant. Not sure if that’s a bug or not.
Jul 3, 2023 1:35 PM UTC
What I described above should work like this:
And your case, if I understand correctly, should work as a scrollable list-wheel?
Then you will need 5 variables and 3 variants, each of which should contain 5 items.
Duplicate the file from the link below to explore the interactions in more detail.
Figma – 3 Jul 23
halkiona
halkionaAuthor
Jul 3, 2023 3:25 PM UTC
Perfect. That worked like a charm. Thanks so much for your help 😀
halkiona
halkionaAuthor
Jul 6, 2023 2:42 PM UTC
Do you have any idea how to make it go in a loop? E.g. from 0 to 30 and then again 0. I tried different conditionals but I’m struggling which variable to use as a condition <=0 and >30.
Jul 6, 2023 5:35 PM UTC
Write conditions for each variable in both Minus and Plus variant interactions.
For example:
halkiona
halkionaAuthor
Jul 7, 2023 9:42 AM UTC
I did what you said and it still goes below zero. Not sure why. Each conditional here has the same condition just for a different variable. And I did the same for Plus variant with minTemp and maxTemp reversed. minTemp is 0 and maxTemp is 30.
Jul 7, 2023 9:53 AM UTC
Could you share a link to the file?
halkiona
halkionaAuthor
Jul 7, 2023 2:06 PM UTC
Hi,
See the file here:
Figma
I noticed it’s working when the increments are by 1 degree but when I change it to 0.2 it doesn’t work. That is odd. Why should a decimal make any difference to a mathematical formula?
Jul 7, 2023 7:08 PM UTC
Unfortunately, there are no tools for debugging variables in the prototype. So I had to go a little deeper.
I think this is due to the way Figma handles decimal numbers. Here are the values of the variables that are obtained using the API:
variables
To fix your prototype, change the == operator in the conditions to <=, >=. Also, in the interaction conditions of the Minus variant, instead of the “minTemp” variable, use another variable or a value of 0.15 or something like that.
Since the variables are currently in beta, various bugs and shortcomings are possible. I suggest you to share your feedback on variables and advanced prototyping.
