Hi everyone! I just got to discover the world of variables and tokens and I seem to be missing some info regarding the semantic and base tokens. I am wondering if the flow is intended to sort of go; First define base colors (aka base tokens), and then secondarily use those predefined colors to define semantic tokens? So basically using the same hexa code but naming it differently? Not sure I explained myself properly 😬. Or if someone has a good resource on the topic of semantic and base tokens that would be great! Thanks 😊
Do you apply colors defined as base tokens in semantic tokens?
Best answer by Blagovirnyy_Roman
Hi Anna, here’s how I would do it:
Define a base color palette. The colors here are not opinionated, meaning that at this level you’re not declaring what a specific color should be used for. It’s just a name and value, e.g.
--color-base-red-200 = #FF0000
--color-base-dark-900 = #000000
--color-base-light-700 = #EEEEEE
For each component, define a set of alias variables and assign specific base variables to them as values. E.g., for the error variant of the Toast component:
--color-toast-error-icon = --color-base-red-200
--color-toast-error-text = --color-base-red-200
--color-toast-error-background = --color-base-light-700
--color-toast-error-border = --color-base-dark-900
Assign the alias colors to the strokes and fills of the layers in your component.
In this setup you can make global changes by changing your base color palette (e.g., changing the value of --color-base-red-200
from #FF0000
to #EF0000
to better align with the recent changes to brand guidelines) and make local changes at the component level based on mode/variant/state/theme/context:
For light mode:
For dark mode:
--color-toast-error-icon = --color-base-light-700
--color-toast-error-text = --color-base-light-700
--color-toast-error-background = --color-base-red-200
--color-toast-error-border = --color-base-light-700
You can consider another middle layer of alias variables between base- and component- level variables (e.g., a ‘default’ color for text: --color-paragraph-text = --color-base-light-700
). However, additional layers of abstraction may make things more complex, as things like color use are highly dependent on context, state, etc (e.g., what’s a paragraph? what about quotes within a paragraph? what if it’s a paragraph in a tooltip? etc).
Another suggestion here: you may want to consult with your engineers to align on the theming and variable naming approach they are thinking of using in CSS or whatever component framework they have in mind. This may be especially relevant now that we have variables in Figma and developers will be able to see the names of these variables in dev mode. It will make everyone’s jobs easier if you are using the same variable names in Figma that they have in code in the same way because you will be speaking the same language.
