Difference between frame and "shift A" frame
Teri1
Can someone explain me, what is the difference between
  • when I do a rectangular and press “shift A” and make it a frame
    and
  • when i frame the rectangular with the “Frame” tool
Thanks 🙂
Snímek obrazovky 2024-01-10 v 15.40.21
Best answer by Haroll
Well it depends. There’s different way of thinking among designers: I find auto layout interesting because it mimics how developers work (at least with web and iOS) and I think its important to work with some of their constraints so design don’t become over complicated.
Also it’s important that the software serve you well rather than being to demanding for creating anything. Some founds auto-layout hard to work with, because of all the rules they impose.
I’d say both have specifics usage :
Whenever I need to create a system with logic and rules (i.e: a list of element) I tend to use auto layout, because i can defined that logic only once on the parent (= frame) and all children will behave the same so I won’t have to check if every children are spaced evenly. When working on a view that will have both a desktop and a mobile usage I also use auto layout because I can change the direction (i.e: horizontal in desktop and vertical in mobile) within a click and my design will re-arrange itself.
Classic frame are for everything else*
I’d say you play with both and decided what you like best. But if I were you I’d give a good try at Auto layout as I find them very powerful to use
Haroll
  • January 10, 2024
Hi @Teri1
Frame 2 is your classic frame while Frame 3 is a frame with a twist : an auto-layout. It change the way elements inside a frame behave :
  • in a classic frame they behave wildly regardless each other
  • while in an auto-layout one they position according to the parent’s rules and to their siblings
Hope it helped!
Teri1
  • January 11, 2024
Thanks! So there are no pros in using the “classic” one? I should always rather use the “auto-layout frame”?
Haroll
  • January 11, 2024
Teri1
  • January 17, 2024
Thank you!
