Dev-Mode display actual HTML button
  • July 12, 2023
  • 565 views
In dev-mode, you can add a code snippet, like a short html snippet. Is there a way, to add an actual html-button in dev-mode? I’m asking because I want to create a button in dev-mode, that when you click it opens an ifram using figma.showUI with the documentation for the selected element.
Best answer by tank666
You can’t change Figma’s UI using plugins, but you can create a plugin that works in dev mode on both the Inspect and Plugins tabs.
Please see the following plugin sample:
github.com
github.com
