CSS -> Is there a change in the CSS text case display
  • January 2, 2024
  • 186 views
ivan.duzdagic
Hi,
after the last update, we noticed that Figma changed the text case in DEV mode.
Before it was shown like this:
var(--base-white-900, #FFF);
And after the update, it is like this:
var(--Base-White-900, #FFF);
So the question is if there is some way to keep the old way of showing lover case instead of the new way → Capitalized Case as it is trouble for web devs and they can’t copy CSS directly from Figma anymore as they need to use lower case.
Is there any workaround?
Celine_
  • 3725 replies
  • January 3, 2024
Hey Ivan,
Thanks for reaching out to the community. After checking internally, our team would like to investigate further. Would you mind sharing a link to the file, and share the file with support-share@figma.com (with edit access)? (this won’t affect your billing at all)
If you are hesitant to share your file publicly, please reach out to the support team by filling this form: https://help.figma.com/hc/en-us/requests/new Thank you!
