Console error after using importComponentByKeyAsync(key)
Hi my plugin currently places an instance from my library on the page. If I then click and move the instance console reports the following error
caught Error: "Variable data not found in consumption map entry" in buildUpdateForUI (FGDerivedSelectionProperties.cpp)
    at _reportError (compiled_wasm.js.br:2:108334)
here is the code:
   const componentKey = "b46ad4dd5247c059da9597e511b2042814ccc0f4";
   // Obtain the page where you want to place the component
   const targetPage = figma.currentPage;
  function placeLogo() {
    figma
      .importComponentByKeyAsync(componentKey)
      .then((component) => {
        // Create an instance of the component on the target page
        console.log(component);
        const componentInstance = component.createInstance();
        // Set position and scale of the component instance
        componentInstance.x = 100; // X position
        componentInstance.y = 100; // Y position
        componentInstance.resize(200, 200); // Width and height
        // Add the component instance to the target page
        targetPage.appendChild(componentInstance);
        // Zoom to fit the added component instance
        figma.viewport.scrollAndZoomIntoView([componentInstance]);
        figma.closePlugin();
      .catch((error) => {
        console.error("Error importing component:", error);
  placeLogo();
If i drag the same instance on to the page there are no subsequent errors.
Thanks in advance
This is an internal error of Figma, and does not apply to the Plugin API. Or is this error affecting your plugin?
Its not effecting the plugin but i’m worried Im not writing the code properly
