Component resizing/scaling behaves weird
  • August 28, 2024
  • 4 replies
  • 443 views
Zinah_Insignia
Hej guys,
I have a set of icons, they’re in a main component as variants. All variants have the exact same settings, but still resizing leads to different restults. This also effects the instances, which makes them kind of unusable in other components.
I tried literally everything I could think of or found using the search, I tried using groups, frames, auto-layout, all the different auto layout settings, adding strokes, editing the vector, and and and… nothing helps. I’m desperate. This also happens when I throw two scaling/not scaling icons into one variant – one scales fine, the other one refuses to do so 😦
Best answer by Gleb
Constraints Why are some elements moving on my frame and not others as I increase length? - #2 by Gleb
  • 4710 replies
  • August 28, 2024
Zinah_Insignia
I also tested different constraints settings – doesn’t change anything. They just refuse to scale.
  • 4710 replies
  • August 28, 2024
send the file example
Zinah_Insignia
Well, seems like Figma had a hickup. Today it … works. 🤦‍♀️ Now it’s accepting given constraints.
