Component properties showing in the wrong order
  • November 22, 2024
  • 7 replies
  • 88 views
Alice11
Main component has the properties in order 1, 2, 3, 4, 5, 6
Instance of the component in another file properties are in a random order 1, 6, 5, 4, 2, 3
Any ideas how to fix? 💡
  • 4 replies
  • December 3, 2024
I have the same issue here.
reloading the file does not help. please fix this!
AntoineP
  • 24 replies
  • December 3, 2024
Yes, same issue. However the title of the post is misleading since it’s the property values that are showing in the wrong order, not the properties themselves.
Gayani_S
  • 2159 replies
  • December 3, 2024
Hey everyone, thank you for flagging this! It does sound like the tool isn’t behaving the way we’d expect it and I understand the frustration!
This behaviour unfortunately seems to be related to a longstanding bug in Figma which can cause a discrepancy between the order of variant properties between the local (library) file and the imported copy of the component created in subscribed files.
I have noted these cases as an example in our open bug report for the issue but I also want to be transparent that this will not have an immediate resolution to reinforce the desired properties order and the team will require more time to fully investigate this. While I can’t promise a quick fix, please know that our engineering team is aware of the issue and will work towards finding a solution in the future. We appreciate your understanding and patience in this matter.
In the meantime, our team has suggested a potential workaround that may help resolve the issue. Could you please try the following steps?
  1. Go to main component sets with the issue, apply a small change to a property of the component. For example, like reordering the properties.
  2. Publish the change
  3. Go to a file with the issue, accept library updates and see if the issue is resolved
  4. Go back to the main component and reverse whatever test change was applied (reorder the properties back to the original order, do not use undo).
This method of pushing a controlled update in all of the dependent files usually gets instances back in a normal state moving forward. Can you confirmed if that resolved the issue or is the incorrect order still showing?
If you have any follow up questions or want to check on progress, let me know and I’m happy to assist.
Marvin-aedifion
This potential workaround is not working, no.
Gayani_S
  • 2159 replies
  • December 6, 2024
Hey @Marvin-aedifion, thank you for giving the workaround a try, and I’m sorry to hear it didn’t help. I’ll make sure to report this back to our team right away so we can look into it further.
I appreciate your patience as we work on this.
Martin_FM
  • 5 replies
  • December 13, 2024
I’m having the same issue. I tried changing the order of properties by dragging each one manually and even changing the order of layers of the component, but the issue persists. Hope you can give me a solution (if there is one) or the bug gets fixed soon.
Celine_
  • 3733 replies
  • December 19, 2024
Hey everyone – I am working closely with Gayani.
Just wanted to update everyone that we are pleased to inform you that our engineering team have deployed a fix for this issue. To resolve this in your files, can you try the steps again that Gayani sent previously? Here they are again:
  1. Go to main component sets with the issue, apply a small change to a property of the component. For example, like reordering, and then reordering back to the expected order (do not use undo) to undo the change.
If you continue to experience the issue, please let us know and we will flag it down for further investigation! Thank you 🙏
