Compare changes on the Publish screen
Jason_Sparks
Please introduce compare changes to the publish screen (similar to how you have when comparing branches). Currently if you want to publish something all you see is a tiny thumbnail and no details of what the changes are.
  • Figmate
  • 2235 replies
  • January 26, 2024
Hi @Jason_Sparks , Thanks for sharing your thought!
I totally understand how it would be beneficial to have a compare change in the publish library modal window. We will pass your idea along to the team for future consideration!
In the meantime, please don’t forget to vote up your idea (There is a vote button above the topic’s title).
Thank you!
Artaherzadeh
  • 28 replies
  • September 3, 2024
When we publish a library, we can see what components are updated but we can’t view them and compare the new updated version with the previous one. It happened many times before that I just pushed the update because changes were a lot and it was impossible to review and compare.
When we select the component, we should see another page and compare the changes.
Laura_Boetcher
Upvoting this feature request, as well as the older one with more votes that was closed in Dec 2023. Please give us a way to preview changes to a component so we can write accurate commit messages when publishing. Even the same side-by-side comparison when accepting the changes would give us the insights needed to note changes in the commit message. 🙏
Kate_MacDonald
Upvoting this feature. It would also be great to be able to identify if the library change is only name or description changes as opposed to a component design change.
Roman_Luks
  • 10 replies
  • May 21, 2025
Currently, we can only see “Modified” on publish but have no idea what was modified!
We should be able to open a comparison window on the publish screen to quickly compare changes for each modified component.
