Change default rem size in dev mode
turutan1k
How can I change default sizing rem (16) in dev mode at figma web?
First time when i used figma, i went into dev mode and paste default rem size into 16. Where i can change this sizing?
dennsi
  • 257 replies
  • June 27, 2023
I cannot find it either. I can just switch between px and rem units in Inspect panel but there’s an input missing to define the base rem value.
  • 4873 replies
  • June 27, 2023
  1. Select any object;
  2. In the Code section, click on the settings icon (Inspect settings);
  3. Select “Set unit scale…” item.
dennsi
  • 257 replies
  • June 27, 2023
Perfect, thank you!
Unfortunately this is way too hidden and should also be displayed in the default Inspect Panel as well.
