Can't Login on desktop app
Just_A_Umbreon
I’m new on figma, I’ve used like two times figma on my web explorer and then I download the desktop app, I started the application, it says I need to login on my explorer
all normal it opens the page then i make a click on open desktop app (because I’ve login on my browser) but there’s nothing happened make a click again but nothing, I’ve attempted 6 times but nothing
Then like 3 or 4 minutes it says this
Device specifications:
Windows 10 home Single Language last update installed: Windows 10 20H2 KB4023057
Processor: Intel core i5
Arquitecture: x64
Ram: 8GB
Windows Language: Es-MX
Browser: Edge (Even I’ve tested with another browser (Chrome) and it’s the same)
Hope someone can help me
Deon
  • May 17, 2021
I have the same problem, also on Windows.
Did you find a solution?
Gabriela_Torres
Hello, I been trying several times to login to Figma desktop but the browser tab it doesn’t show and I dont know why. What could be the problem?
Gabriela_Torres
I have the same problem 😦
Just_A_Umbreon
Yes I find something, For some reason, I wait just a little and install and uninstall figma and it works! I don’t know why but, that works to me, I don’t know if it’s the real solution, but I remember I made it when I had the problem. Hope It works!
obog
  • October 5, 2021
It doesn’t work on the desktop. Issues with logging in. Disappointed. Don’t use anymore.
Almira
  • November 19, 2021
same here. I can login into desktop. I’ve tried to uninstall but nothing happen. Please fix this, i need to use it asap. thankyou
Learn_kom
  • December 5, 2021
the same problem arises with me!
Desktop application does not show anything in saved projects but works in browser.
how to solve this issue?
help plzzzzzzzz!!!
Joshua_Lim
Hi there facing the same issue over here on windows. Any remedy or solutions currently.
Chandeshwar_kr
try using different browser. I had the same problem. I changed my default browser to microsoft edge and completed the login.
MaksimKolesnik
Thank’s, it worked!
Ichisaki_Mitsu
Thanks Bro, its work for me, you just change the default browser to edge, then login and voilaa …
John_Schram
The desktop app is Electron, it’s more than capable of hosting a login flow. Requiring an external browser is kludgy and lazy Figma.
Hafidz_Kusumah
Same here hahaha, please figma read it and please fix it
Cause I can’t use figma desktop and I’m not used to using figma in the browser
angela_kwek
Same. I don’t like using the browser because it is laggy and the zoom doesn’t work properly. But the desktop app is giving me a real headache logging in and also loading my file. Takes forever and it doesn’t load.
Tried deleting the app and downloading it again. Tried logging in using a different browser. Chrome, edge. Mozilla don’t allow me to open because it’s unsafe, or has some missing certificate. Tried signing in using different account. Tried creating a new account. Nothing seems to work.
Why do they need to link it to browser to authenticate?
Marcin_Woroch1
I had similar problem but on Mac. What helped was clearing the cache, as described here:
Figma Help Center
The exact command I used before restarting Figma:
rm -rf "$HOME/Library/Application Support/Figma/"{Desktop,DesktopProfile}
Maybe it will help in your case too?
Abaadi_San
thank you… it works ! I change my default browser to edge … and that solve the issue
Tejashree_Barve
Thanks for all the suggestions. I set my default browser to Safari and it worked.
mehdi2
  • July 4, 2022
hi every one
I ran the program using administrator and the login problem was fixed.
If anyone solves the problem with this method, please let me know. Thanks
Robert_Campbell
Launching desktop app as administrator solved my problem. Using Chrome as default browser.
zeinab_shakeri
Thank’s for your help, it worked!
timothy_shen
This is so dumb man, I used edge and it worked XD. tried on Chrome multiple times. Many thanks to the people here!
Jing_Xian
  • September 21, 2022
Yes. As of 21th September 2022, the bug is still there.
Unable to login to Figma Desktop App with chrome. Need to switch to Microsoft Edge, then it’s working.
Jack_Rokub
You go to default apps settings and there reset your default apps. Then go to figma desktop app and try to login again, it will open microsoft edge browser and there you login.
David_Nine
SOLUTION:
  1. Open Figma in your browser
  2. open any active project
  3. go to left upper menu (with figma logo) an in the list press open in desctop app
  4. done.
after it opens, app runs perfectly, even if u close it…
thank me later … much love guys
worked for me
