Button text not showing in editor
  • May 10, 2024
  • 166 views
Gradiweb
I am finishing a design for a client, but the client tells me that they cannot see the text on the buttons in the editor (image attached), and the same issue occurs for several other people. Instead, I’m the only one who can see the text without any problem in the editor view.
Could this be a Figma bug? Do you have any ideas why this is happening?
Thanks in advance.
ksn
  • 1687 replies
  • May 13, 2024
@Gradiweb On the surface, this may be an issue with the font you’re using in your design – is the font you’re using a downloaded/custom one?
If it’s a custom font and all users you’ve shared the file with have it installed, it may be that you are using a different version of the font (ex: your font is updated).
If that’s not the case (because you’re using a default font), can you share a copy of the file + the name of the font you’re using? I can take a look to see if I can replicate it myself.
