Branching - Update from main file Conflicts - Stuck
Matthias
Hello!
I have created a branch of my design system to introduce the variables feature.
Bug fixes still happened in the main file.
Now I’m done with the variables and I want to merge them.
But when I start to fix the conflicts, Figma gets stuck.
No matter if I open it in the browser or in the standalone app.
Reloading it doesn’t help either.
Figma memory is still green with a maximum of 44%.
Is there any way to automatically settle on “keep main” to bypass the conflict modal?
Maybe there is another solution that will help me.
Many thanks!
Matthias
Ryan_52
  • 382 replies
  • July 26, 2023
Hi @Matthias sorry to hear this is happening! Can you reach out to our support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Please be sure to include a video of the issue along with the links to the file and branch you are having issues with and share it with support-share@figma.com so they can take a closer look.
Dominik_Maier-Posch1
same here. whenever i try to resolve conflicts in our component library it gets stuck. i eventually get through it but it’s a tedious, painful thing to do.
i never get to see the preview for both branches, clicking a button takes several minutes until it moves to the next item, i have to trust my knowledge of layer names to select the right version.
what i can do is click the “keep main” button multiple times (if i know exactly how many items i can keep from main branch) - it still takes a few minutes but at least it resolves a few items at once.
it just took me about 30+ minutes to fix 18 conflicts.
horrible experience and i’d really need to use branches but i’m considering moving away from it, cause this happens every time!
(side note: memory usage shows 18% for the file in question)
VarunYellina
  • 4 replies
  • February 17, 2025
I’m stuck with the same. I don’t have options to select the desired branch to resolve the conflict.
Figma - 125.0.8
macOS - 15.3
VarunYellina
  • 4 replies
  • February 17, 2025
Figma - 125.0.8
macOS - 15.3
Had to restart Figma. The conflicts are no longer there. Vanished magically.
