Automatic Change Text Color When Using CSV Populate
Hi,
I’m makeing some text designs and giving each letter a different color (5 different colors and then going back to first color and repeating). Now when I use the Plugin “CSV Populate” (https://www.figma.com/community/plugin/875365065394448755) or “Find and Replace” It does change the text, but the color is no longer 5 different colors but instead the color the of the first letter.
I’ve tryed the “copy properties” but that only copies the text style not the colors.
Is there any way I can apply the colors automatic instead of changing each letter manually again?
  • 2488 replies
  • January 30, 2024
Thanks for the post! To confirm what you’d like to achieve, would you like to do kind of this?
Hope to explore a possible solution together!
Hi Toku,
Yes that is excatly what I’m looking to do.
I do however also want it to color symbols with the exception of spaces if thats possible (.,^'^#_-! and so on).
Sincerely
Christian
Hi Toku,
Sincerely
Christian
  • 2488 replies
  • February 6, 2024
Thanks! Though I asked you to clarify, I’m not sure how to achieve it yet. Probably, making an own plugin would be the solution since this is not achievable with the built-in feature, I think. I really hope somebody from community will find the solution!
I have never tryed to code nor make my own plugin. I tryed asking ChatGPT which came with a code for it. But how do I even make that?
Javascript:
// This is the entry point for the Figma plugin
Figma.showUI(html);
// When the plugin is run, this code will execute
Figma.ui.onmessage = (msg) => {
if (msg.type === ‘applyColors’) {
// Get the selected text node
const textNode = Figma.currentPage.selection[0];
if (textNode && textNode.type === 'TEXT') {
  const characters = textNode.characters.split('');
  // Get user-defined color palette
  const colorPalette = msg.colors;
  // Apply colors to each character
  characters.forEach((char, index) => {
    if (char !== ' ') {
      const colorIndex = index % colorPalette.length;
      const color = colorPalette[colorIndex];
      // Set character color
      textNode.setRangeFills(index, index + 1, [{ type: 'SOLID', color }]);
  // Close the plugin
  figma.closePlugin();
} else {
Html:
Colorize Text Plugin body { display: flex; flex-direction: column; align-items: center; justify-content: center; height: 100vh; } input { margin-bottom: 10px; } Number of Colors:
Color 1:
Color 2:
Color 3:
Color 4:
Color 5:
Apply Colors
  • 2488 replies
  • February 8, 2024
Thanks for replies! Here is a plugin development guide - https://help.figma.com/hc/en-us/articles/360042786733-Create-a-plugin-for-development.
It might take time to learn coding, but I think it’s a great idea to use AI to make a plugin!
I hope these help.
Thanks alot, I’ll try looking into this 😁
